- Thank you received: 872
Valve extensions
3 years 1 month ago #219548
Replied by cobbadog on topic Valve extensions
There is no need for any zip ties on mine as they simply dont move, no rub marks or anything. Mind you they have only done about 5,000 klms since fitting because he only comes out for rallies or to pick up long loads of building supplies when I need to build another carport.
3 years 1 month ago #219552
by raafy
MOVED FROM CAIRNS TO VICTORIA & STILL TRYING TO WORK OUT WHY
Replied by raafy on topic Valve extensions
I use a socket that I have put a grommet in to put through the rim to take the cap off. This works well with the buses I work on.
3 years 1 month ago - 3 years 1 month ago #219578
Replied by Swishy on topic Valve extensions
50 odd years ago we tried Schrader valve extensions
more tuble than they worth (spose we R ruff on the gear)
best to bend the valve stem to make m user frindly
bend by using a loose bit of pipe n bend blow where the vale insert hangs out
the inner wheel we use the valve cap
th@ looks like thiz n
and the right double ender tool to remove cap or valve stem
Last edit: 3 years 1 month ago by Swishy.
Time to create page: 0.660 seconds
