- Thank you received: 4767
Walter Wright's Heavy Haulage
7 years 2 months ago #179834
Replied by Mrsmackpaul on topic Walter Wright's Heavy Haulage
Ok I have way to much time on my hands but doing some more googling before back out to the paddock and found this on the forum with some more info on these old trucks
K.W.Dart
K.W.Dart's Avatar
OFFLINE
Hi i work for Lampson Aust in Perth and we have one of the Kenworth Darts here in Perth and is still in use today. The other one is in our Gladstone yard. They are both fitted with 12/71 GM, Alison auto's and Clark diff's and have a top speed of 27km per hour @ 2500 rpm. I will post some pic of the last job we did in W.A. with the old girl towing a 14 axel Goldhofer platform with a EX3600 EXC when i work out how to do it.
Cheers Norm
www.hcvc.com.au/forum/truck_Chat/1408-wh...eet-express?start=30
K.W.Dart
K.W.Dart's Avatar
OFFLINE
Cheers Norm
- Thank you received: 839
7 years 2 months ago #179835
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Walter Wright's Heavy Haulage
.Yep.........Paul.....
There would be heaps of different models.....
I am just guessing......but with that super heavy set up...i would suspect that it could have had Locker centres
seeing as it liked to go straight ahead (only under loaded conditions probably, depending on the amount of
ballast on board )
Of corse...it all depends on how the truck buyer specs the thing .as to how it goes on the road..............
When i said the Clark came as standard with the Locker, i was referring to the particular axle we fitted at the time.....
I would assume that mostly the Locker may be added as an extra gismo.
..................................Billy.....................................
ballast on board )
7 years 2 months ago #179892
by defective
Replied by defective on topic Walter Wright's Heavy Haulage
Yes Rex .. but that big banger Kenworth is waiting in the wings in case it all goes pear shaped ol' mate ! lol.
7 years 2 months ago #179896
Replied by Swishy on topic Walter Wright's Heavy Haulage
Guyz
Moons ago the KW 1/2 truck came with a LSD diff (limited slip diff)
n way back when we were do n a few runs upto the upper thompson dam
Melb thru to Warburton , Cumberlan Junction then wide gravel road all the rest of the way
most vehicles were able to cut the cnrs n tha@ heaped the loose gravel up on the unused outa circumference of the cnrs wasn't unusual on the hills with full poweron (may be only 50-60 kph) th@ the diff would lok up n tend to push U straight ahead on cnrs ..... also with Jakes on ....... same thing twould happen cum n in to a cnr
So guess n the clarke diff lockers were do n there job n supply n power to all wheels
ยง
ยง
7 years 2 months ago #179897
Makes sense Swish Man if full speed in them big KW was 27 km/h the diff ratio must have been something like 12 or 13 to one
So even at walking pace they would still be spinning fairly quick
On the videos that were put up on the forum it shows them doing a U turn fine but I wonder if that is because they are only rolling slow ???
Or maybe slippery diffs only work once speed is picked up
dunno much about them at all slippery diffs that is
On a farm tractor when pulling hard if you wanna turn it helps to back off to get the tractor to start to turn and once the turn is started it gently apply power and tractors have no slippery diff
7 years 2 months ago #179898
Mrs
in sum of them hills driving max n out there weren't much speed but full power to the ground
= lok n up diff n go n straight ahead
guessn them thar huge screemer V12 powered KWhoppers would/could suffer the same wen on full power
yes U need to back off to gain control to take cnrs
ยง
ยง
7 years 1 month ago #180342
by Pat Hutchings
Replied by Pat Hutchings on topic Walter Wright's Heavy Haulage
Swishy,were the Wlter Wright the same ones that came into Wyndam CKD in boxes & John Ireland, Sandy Negrin & another apprentice whose name I can't remember went up there &put them together in about 1970. They pulled 2 belly dumpers each to build the dam for Lake Argyle. I think they were 9 ft. across the drive tyres & almost that spec.
7 years 1 month ago #180346
Anyone have any photos of these ???
7 years 1 month ago #180348
Pat
sorry me nose nut n
ยง
sorry me nose nut n
ยง
7 years 1 month ago - 7 years 1 month ago #180510
I have been handed some information about this photo I believe by some one a lot smarter and more in the no than I will ever be
"Picture was taken when they had to bypass the overhead walkway at Redbank Plains. When you were leaving Bris, heading outbound on Ipswich Rd,
that overpass was too low for that sort of load, so you turned right across Ipswich Rd and went down the main st at Redbank. Back then there was no
round-a-bouts, or other obstacles to get in your way, just straight of Ipswich Rd into the main st and away you went
So when you came back onto Ipswich Rd, you now had to go onto the wrong side of the double lanes ( using the inbound lanes )until you got to the next
intersection that led down to the Mogill Ferry, then you got back onto your correct side of the road."
So there you go that explains some confusion about this picture
If I had to guess I would have said Debo was right "I'm certain that the 3rd pic is on the princess highway. Moe bypass in Vic on the way to the Latrobe Valley (Loy Yang?) suspect the 2nd pic is the same trip."
And next time I was Moe town I was gunna have a ganda I would have said the photo was taken off the Coalville road bridge out bound towards Morwell
And this photo was taken on Mattengley road on the way out to Loy Yang as this road was a specially built road with very heavy duty bridges and the like
Most of the other photos are taken from were a lot of this gear was assembled and stored when Loy Yang was been built to North of B station there was big assembly areas were sections were assembled before been shifted as a unit to the power station
I cant really explain my interest in these trucks they arent even the right brand but they give me horn or the same
oo roo
oo roo
Last edit: 7 years 1 month ago by Mrsmackpaul.
Time to create page: 0.593 seconds
