- Thank you received: 25
Old Atkinson Identification
2 years 5 months ago #227985
by Muttlee
Replied by Muttlee on topic Old Atkinson Identification
OK. Maybe l can do it for you…
Can you send me a photo of the chassis plate, showing the numbers clearly.
A pic of the cab shape too. Is it fibreglass or a flat front made of metal?
Does it have two piece or 4 piece windscreen?
Cab frame is wood (ash probably) or steel?
What engine, trans and rear axle are fitted?
What axle configuration & application eg 4x2 single drive prime mover, 8x4 double drive, twinsteer heavy rigid etc.
Post them here if you can or send to my email…. duncan4x4@gmail.com
The following user(s) said Thank You: Inter-Action
2 years 5 months ago #227996
Replied by mammoth on topic Old Atkinson Identification
Duncan, he is asking because there is no chassis plate. We know it is a 6x4, wood frame, 2 piece screen.
- Inter-Action
- Thank you received: 313
2 years 5 months ago #228003
by Inter-Action
Replied by Inter-Action on topic Old Atkinson Identification
I am going to try to have another look today. It's been a bit wet last few days. To Muttlee. Wooden frame cab,2 piece w/s, 6 speed g/box, Gardener 6 cyld engine , Kirstalls bogie arse end . There is some f/glass panels up front.
I will check w/s etchings ,photos ,motor model , and some photos today.
- Inter-Action
2 years 5 months ago #228007
by Inter-Action
A bit more info on the Old Atkinson. Sorry the windscreens were not to easy to get to. Also learning to drive this new computer. The cab is all F/Glass.
- Inter-Action
2 years 5 months ago #228008
by Inter-Action
2 years 5 months ago - 2 years 5 months ago #228010
by Muttlee
She's a rippa ol'girl.
I have sent a message to the guy in UK, lets see what he turns up....
This is my mk1 and plate.... She was hauling a fuel tanker around Benalla area l believe.
Earliest 'Preston' cabbed mk1 retained the 2piece windscreen as yours has plus the ash frame. Latter like mine (1965) have a metal frame and the 4 piece. I envy you as l cannot find the curved corner glass and repro glass is $5k for a pair.
I have a digital photocopy parts book for mine. Would you like a copy?
The ash frame is available to buy from UK. I can dig out a contact if you need ?
Gardner engine parts, (filters) etc are easily available in Aus.
The last pic is how yours might look with the body panels in place. Have you got the panels ?
Look forward to seeing yours finished. Mine is on the back-burner currently while l'm getting a RWC on a mk3.
Let me know if l can help
Duncan
Duncan
Last edit: 2 years 5 months ago by Muttlee.
The following user(s) said Thank You: 180wannabe, cobbadog, Inter-Action, Mrsmackpaul, PaulFH, oliver1950
2 years 5 months ago #228015
I saved a airport tender cab from a scrappy for the screens. Is now in Brissy and could be bought at a reasonable price. I am assuming the screens would be the same size & fitting.
2 years 5 months ago - 2 years 5 months ago #228022
by Muttlee
Apparently there is a number stamped onto the left rail also. Approx where a fuel tank wiuld be and its on the radius, not on the vertical.
Might be coveredby multiple layers paint so a careful sand back might find it.
He can give you the build sheet from factory once the number is found.
Pic below.
Pic below.
Last edit: 2 years 5 months ago by Gryphon.
2 years 5 months ago #228031
by Muttlee
Hi Mammoth, Is the cab like mine with 4pce windscreen ?
Whats the fibreglass like and has it got complete doors fitted so l could swap it straight over ?
I’d be really keen on it if available.
2 years 5 months ago #228032
Traditional radiator and a dot under the G of toughened makes it 1964. Still need to see what is on the other screen and rear windows in case there is a variation.
The "kitemark" is the British Standard logo
The following user(s) said Thank You: Muttlee
