steering bump
9 years 1 month ago #174875 by mammoth
Replied by mammoth on topic steering bump
The symptoms you described are of nil suspension movement, nothing to do with steering etc. If the shackle pins are free the culprit would appear to be the shock absorbers and the easy way to test is to remove them and go for a drive. If it is the shocks that are wrong it will then handle more like a yank car - all soft and bouncy. Only make one change at a time to eliminate a suspect item. Part of your trouble here is that so much has been dismantled, replaced and played with, all without benefit of a workshop manual. The only wedge in a light weight Bedford is the potato chip to keep the passenger quiet.
Another principle of old vehicle restoration is that if you are going to pay for someones education it should be your own (or family member) and not some so called professional mechanic who is learning at your expense. Keep plugging at it and let us know how you get on.
9 years 1 month ago #174877 by Blackduck59
Replied by Blackduck59 on topic steering bump
Rusty,
Which patch of the planet are you located?
9 years 1 month ago #174881 by Fill
Replied by Fill on topic steering bump
My Bedford is a J2
[img
100_2504 by fill quinn , on Flickr
I took this photo before I took it apart
9 years 1 month ago #174882 by Fill
[img
100_2831 by fill quinn , on Flickr
[img
100_2830 by fill quinn , on Flickr
[img
100_2829 by fill quinn , on Flickr
Your wedges are ready
Cheers Fill
9 years 1 month ago #174897 by mammoth
I stand corrected on the wedges. Interestingly the early J series handbook I have indicates that shockies were optional. I would guess they would be standard by the 70's
9 years 1 month ago - 9 years 1 month ago #174901 by asw120
Replied by asw120 on topic steering bump
I think Mammoth may be onto something here.
My little Inter with new (urethane) bushes was like this - I had to back everything off a bit until it bedded in.
Also, I would think 70 PSI is far more than required. I wouldn't run more than 40 usually in 7.50 rag tyres, except I do have 45 in the front to reduce the shimmy. Rag tyres will normally show quite a flat spot even with correct pressure.
Best of luck, Jarrod.
Last edit: 9 years 1 month ago by asw120.
9 years 1 month ago #174903 by jon_d
Replied by jon_d on topic steering bump
I don't know if this will help or not.
I checked my Truck and Coach manual, TS1086.
It says the thick end of the wedge is marked either front or rear and needs to be fitted accordingly.
9 years 1 month ago #174907 by Kwakatriple
Replied by Kwakatriple on topic steering bump
My Bedford SB3 is very sensitive to castor changes so I would get that checked again. If I remember correctly we had to go slightly more castor than the book says to get it driveable.
1964 Bedford bus/motorhome
1972 Bedford bus/motorhome
...and sundry other 2, 3 and 4 wheel vehicles...
9 years 1 month ago #174957 by Rustyb
Replied by Rustyb on topic steering bump
Hi Fill,
washes all organised, will send to you when I
9 years 1 month ago #174958 by Rustyb
Hi Fill,
washes all organised, will send to you when I get them mate.
Regards
Russ
still working on the bump
Time to create page: 0.311 seconds
