- Thank you received: 8181
Bedford restoration with Chassis extension.
4 years 8 months ago #224500
So to answer the question about fitting a turbo and will it increase performance and how clean it runs
Not sure you asked about performance but heres my thoughts that are probably wrong
A diesel motor will blow smoke until the air fuel mixture ratio is correct, all the fuel is getting burnt
Once all the fuel is getting burnt it wont smoke as the smoke is unburnt fuel
So to get further into this line of thinking we have understand this
So if you dont have a turbo and add one that is sized correctly will enable you to obtain that mixture balance far earlier
Now I would start by doing some simple googling to size a turbo
The turbo should add power and clean the exhaust up, but only to a point, once the exhaust is clean that is all the power you can obtain as all the fuel is getting burnt
A cheap Chinese turbo is probably cheaper than sourcing one from the wreckers and it is probably higher quality
Anyway I think it would be worth the experiment
Dont know about the Hi clone and wouldn't really pass an opinion either way
I think a lot of people bag the pommy gear but technology was a long way from say even 30 years ago and it did a good job for what it was
And the aircleaner question, could you get one of those aircleaner restriction indictors and actually see if it is a issue ?
Replied by Mrsmackpaul on topic Bedford restoration with Chassis extension.
Another question for the brains trust
Although she runs ok, she blows a bit of soot
I was thinking(dangerous), that it might be worth putting a larger air cleaner or maybe even a turbo to cram a bit more air in there, not looking for power, just trying to eliminate a bit of soot
The original air cleaner has a 4 inch inlet
The pipe from the cleaner to the inlet manifold has a 2 1/2 inch hose and the air cleaner base has an asmatic. 1 1/4 outlet hole in it
Doesn’t make sense.
4 years 8 months ago #224501
The following user(s) said Thank You: Bitsa
4 years 8 months ago #224533
Replied by asw120 on topic Bedford restoration with Chassis extension.
4 years 8 months ago - 4 years 8 months ago #224678
by Bitsa
Replied by Bitsa on topic Bedford restoration with Chassis extension.
Last edit: 4 years 8 months ago by Sarge.
4 years 8 months ago - 4 years 8 months ago #224680
by Bitsa
4 years 8 months ago #224681
by 600Dodge
Replied by 600Dodge on topic Bedford restoration with Chassis extension.
PMG orange? I'd like one of these 4x4 Bedfords but it would have to be 308 Holden powered.
4 years 8 months ago #224684
by wee-allis
Replied by wee-allis on topic Bedford restoration with Chassis extension.
Should be able to see you coming!
4 years 8 months ago #224686
Replied by cobbadog on topic Bedford restoration with Chassis extension.
Nice one, at least you should never bump into it on a dark night.
4 years 8 months ago #224689
Lucky it wasn't ex- Farley and Lewers.....
I don't mind Telecom orange at all
4 years 8 months ago #224694
by Bitsa
Yeah Dodge, I’m with you
If the 330 dies before me, it’ll be a 383 Stroker set up for Torque and cruising speed
Can’t beat the General
Time to create page: 0.331 seconds
