1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
11 years 7 months ago #97147
by D1310m
Replied by D1310m on topic Re: 1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
Hi swamprat, thanks for that. What manual are you referring to??? Is it for a D1310?? also have test fitted bearings to stub axles and they go on too easily with no friction. ie they just slide on, may need to use the ''punch'' technique mentioned in an earlier reply, I expected a tight fit for the bearings, but not the case. Any suggestions? Thanks, Mike T p.s. any ideas where I can find Inter parts for a D1310?
- Thank you received: 4876
11 years 7 months ago #97148
Replied by Mrsmackpaul on topic Re: 1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
I use loctite bearing retainer stuff just hope you never have to get the bearing off you will need a gear puller I've had no problems even really stuffed shafts bearings stay were put
11 years 7 months ago #97149
by Bugly
Replied by Bugly on topic Re: 1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
savin' the best 'til last, huh?think Darwin is the only place i havnt driven it yet ,
11 years 6 months ago #97150
by swamprat
D1510 International 4wd 6BT cummins power steer
Replied by swamprat on topic Re: 1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
the manual i have is D series chassis manual , covers all the d models , what parts are you chasing , ive got a couple 4x4 that ive wrecked , or i can still get some new parts
11 years 6 months ago #97151
by D1310m
HALLELUJAH!!!!! Wow, didnt think they even existed! Can you tell me where you got the manual, as I really need one. Also if its not too much trouble, can you let me know if you have any of the following: front brake linings, drum diameter 304mm x depth of lining and 44.4mm, stub -axles from a 4x4, any front wheel bearings NTN 131107 or Timken 18685, cones to fit, seals: imperial size: 2.250 3.250 0.375 inches. As the engine is a 7.3l V8 diesel it is not the original engine (heart transplant a while ago), I dont need motor parts, just running gear and other bits n pieces . Thanks a lot, Mike T :)ps where are you, as we are heading south early Nov and going thru SA then into Vic, NSW, and up thru Qld on way back to NT mid year. Could call in and check out your bits, if that ok for you?
11 years 6 months ago #97152
by swamprat
you should be able to buy brake linings from a local brake shop , i think ive got some new front brake drums that should fit 1310 , im near Horsham in western vic , one of the local truck shops still has some new old stock parts from when the fire service used 1310s as fire trucks , bearings & seals should be available from any bearing shop
11 years 6 months ago #97153
by swamprat
ive had my workshop manual for years , most of the info is easy to get as the 4wd components were made by other manufacturers
11 years 6 months ago #97154
by D1310m
Hi swamprat, great info, and Horsham is not far off our meadering route thru Vic. hope to catch up with you in the not too distant future, cheers, Mikie T
11 years 4 months ago #97155
by PeterE
Peter&&Narrogin WA&&AT4 229
Replied by PeterE on topic Re: 1973, Inter D1310m 4x4, front bearing TROUBLES!!!!
Hullo gents
My D1510 4WD (ex fire truck) has a stuck rear brake drum. I would love a look at the workshop diagram before I pull the other side off, please!
So far I have tried to release the adjusters (-butchered by some F--kwit), unbolted and pushed-in both wheel cylinders, cut holes in the back-plate, heated the drum, heated the stiffener on the shoe, chocked opposite wheel with the offending-side wheels off and used engine to try turning drum....
All to no avail. The axle will torque-up and move springs in both directions- but the shoes refuse to let go!
Has anyone got any suggestions, please? Or a replacement back-plate and shoes if I cut it off and get in to them?
I have been trying for 6 months to get it moving and I'm ready to cry in my beer.
Cheers,
Peter
PS. I have parts book for this series if that helps anyone else. The diagrams aren't much use for dissemble work tho'....
Also; am I dream in' or is it possible to put freewheel hubs on the Dana ?
Cheers,
Peter
Time to create page: 0.443 seconds
