Mrs Mack
4 years 11 months ago #218647 by JOHN.K.
Replied by JOHN.K. on topic Mrs Mack
The paw print on the application should have been a giveaway.
4 years 11 months ago #218670 by Mrsmackpaul
Replied by Mrsmackpaul on topic Mrs Mack
Well not a lot to report, got new hoses made for the power steering
The return hose they gave me didn't even touch the barbs let alone grip on them
So back to the hydraulic place today and after been told that the fittings as in the barbs are wrong and we can just silver solder new ones on
Im going nah, this cant be right
The blokes getting pretty frustrated with me but I was sure something was wrong
Yes it was the same as the sample, but it had just been squashed down to nothing with those bolt style hose clamps
Well the boss man walked passed and enquired as to the problem and when the worker showed him the boss looks at me and says, " power steering off a truck ?"
Yes it is
"You'll need this 'Trucker hose' " (yes that is what is written on the hose)
Anyway it fits perfectly and to me was worth the time and effort to chase up as it really is the only oil leak the truck has apart from the winch
Lost the best part of a day sorting that out
Got some new S cam bushes for the front axle, ordered the new hub seals, tried so far unsuccessfully to order the compressor, called Gleemans and for the first time ever found them pretty useless and the fella almost abusive or rude maybe, tried the local to me Mack dealer and was surprised at how useful they were
A lot has to do with whom you get at the counter, the bloke that I first dealt with did the standard "vin number please" after doing this for some years I have all this information on the phone in photos, stops all the "that number isnt right" or "your missing parts of the number" as the photo of the plate is right there in front of them
Anyway another bloke walks past and hears what's goung on and asks a few questions and wanders off to return with the said parts
He was a youngish fella as well so I was quite impressed
So all in all not much progress at all, day 3 of the week is starting and it's getting warmer, so that will add to the excitement
4 years 11 months ago - 4 years 11 months ago #218685 by hayseed
Replied by hayseed on topic Mrs Mack
Mrsmackpaul wrote: , called Gleemans and for the first time ever found them pretty useless and the fella almost abusive or rude maybe,
You're wasting your Time even trying them Now Paul.
They've been bought out (& had a name change) by some Mob who only retail New Truck parts The wrecking yard has (Or is in the Process of being) Closed..
Very sad to see the end of such an Iconic Business ..
gleeman.com.au/
Last edit: 4 years 11 months ago by hayseed. Reason: typo
4 years 11 months ago #218688 by Mrsmackpaul
Thanks for the heads Seed
4 years 11 months ago #218710 by cobbadog
Replied by cobbadog on topic Mrs Mack
Hope you got the name of the helpful young bloke for 2 reasons. You ask for him next time and let his boss know how good he is.
Sounds like you may be supporting the local Mack dealer a bit more now.
4 years 11 months ago #218716 by Mrsmackpaul
Cobba no name yet, gotta go there tomorrow hopefully if parts arrive as planned
Will see what I can learn then
So got the hoses on as far as I can go
Hayseed was right about Gleemans so I ordered a new rebuilt one from Wollongong so hopefully it turn up ok
Got all the front end back together except the wheels and hubs as the new seals havent yet arrived
Funny looking brake shoes, look different than the old ones and actually line up with S cams properly
Also rebushed and re sealed the S cams
Notice the two speings on the lower puns of the brake shoes, normal just a pin with a bolt or a couple of circlips, very fancy and took a while to get the first side fitted
So onto the tip turbine, its all apart and ordered new bearings tonight
So looks like other fun things for tomorrow, my parts from Mack should be in
Also have had some other non truck related stuff turn up so will be kept busy doing other things, fitting automatic sliding gate motors and the list goes on
The floor can be pulled out and the lid lifted off the box
Always something to do
  • Away
4 years 11 months ago #218719 by Swishy
Replied by Swishy on topic Mrs Mack
Mrs
m80
Gr8 info n pix
keep m cummin
R those new brake shoes marked leadin and trailin shoe linings?
eye also notice U run 3 oil filters
this normally depicts ESI motor (Extended Service Interval)
they take a huge amount of oil
we changed the huge sump ovr for a convetional one n do the service wen its due as the same of our other trucks
problem with the huge sump they found the oil twas loos n too much heat they even tried putn a pad in the front of sump to try n keep the heat in
probly more of a problem in nth merica in winter
keep @ it
4 years 11 months ago #218722 by Mrsmackpaul
Swishy wrote: Mrs
Not that Im aware of, I'm pretty sure they are all the same, I'll check tomorrow and report back
  • Away
4 years 11 months ago #218724 by Swishy
the edge of the linings have different colors wiff sum writing on m
4 years 11 months ago #218725 by Mrsmackpaul
Yeah I'm pretty sure thats just cause the shoe is flipped the other way and the writing and different colour is against the backing plate
Will look into it though
Time to create page: 0.320 seconds
