- Thank you received: 1133
Mrs Mack
- Mrsmackpaul
- Thank you received: 8232
5 years 2 months ago #219551
Replied by Mrsmackpaul on topic Mrs Mack
I haven't forgotten you all but I'm having as heck of a time trying to reply
So after I got the lid back on the box I chucked my trusty 20 liter drum for a seat and took Mrs Mack for a drive to prove all was tickety boo before putting t hge seats and floor back in
I felt like I could of been one of the Yanky truck drivers that cruise around sitting on the floor, minus the gear stick touching the roof
So next on to the leaking power steering
Pulled it apart and had to wait for the oil seal, dust seal and speedi sleeve to arrive
Was going to be 4 or 5 days
So chucked it all back together and decided it was time to tackle the float
Many years ago, at a guesd 15 or there abouts I had the pins fixed up like new in the folding part of the float
Cost about the U.S. deficit to get done and like most jobs blew way out over budget
However even spending all that coin didn't get the good result as some how the front sat 6 inches off the ground when unfolded
The rest of the job was perfect though
Anyway the pins were to a fine tolerance and as the float doesnt get used a lot and the grease had gone hard the folding part wasnt exactly smooth
So I remove the grease nipples and used 1/4 " drill bit to get as much dry grease out as possible I then rigged up my doohikie diesel injection gizmo and with the aid of a old air tank, some taps and some small air line and a fitting I forced diesel in while folding the goose neck up and down
There is at a rough count about 30 grease nipples to be done, luckily I had nothing better to do that day
Once all of these were done I then greased them until just new grease was coming thru
- Mrsmackpaul
5 years 2 months ago #219553
I then took Mrs Mack out on the street and placed one side up on the gutter so I could give her a good bath
To me it was a genius plan, all the grease and what not gets washed away and I dont have to lay in the dirt
In reality all I did was freeze my bum off and did a half assed job
So called it a night
Mean while I decided to change a relay valve in the ass end, as quick as I changed this one the other one started leaking
So fixed that and the range change on the box started leaking
I was chasing my tail and decided to try and get some correct coloured air line to tidy the job on gear box
Apparently 1/4 air line of any colour can only be bought in 100 meter rolls
I eventually got hold of a mob in Melbourne that have 20 meter rolls if something happened to the forming of the roll and they will sell the good parts in 20 meter sections
They only had green and yellow so I ordered 20 meters of each
While I was waiting for that to arrive I decided to look into a leaking Maxi chamber
Turned out it was rusted thru but I decided to replace all 4 as I had pumped oil in all 4 of them
Also while doing this the locking doohickies on the slack adjusters had never worked right since I bought the Mack
The grease had always been dry and prevented the lock from just popping out
So I removed the slack adjusters and wire wheeled them clean
I then screw the end off a grease gun onto the end of air operated diesel injection doohickie
I forced diesel thru them whilstspinning them with the rattle gun, I did this until the old grease stopped coming out
This worked amazingly well and they are now as good as new
- Mrsmackpaul
5 years 2 months ago - 5 years 2 months ago #219562
So I then typed out this reply but it vanished so having another crack at it
The winch had a oil leak that puked oil out all over the place and while this wasnt a terrible leak it looks shocking as all the dirt and dust sticks to it and all the dogs and chains and pipes etc that live under the winch are always covered in this horrible sticky crap so replaced a few O rings and that greatly reduced the leaking on the left hand side of the winch , there is still a timy leak on the right hand side but it can wait a bit longer
I was still waiting for the coloured air line to arive so I had a genius moment, yes I do have them and decided th ast parking Mrs Mack up on the float would allow me much better access for cleaning and the like
This worked so much better than the street and a lot less chance of upsetting any over zealous person
I could get right in underneath easier and squirt further than ever before and do a much more thoughr job
I spent hours and hours slowly working my way along tthe passenger side, pretty much a whole day, I have never been this particular in my life but it is strangely for filling and gave me enjoyment, this is very very weird for me
So I decided that enough was enough and was quickly blowing crap of the outside of the truck when it happened
Mrs Mack sprung a leak in her fuel tank
Last edit: 5 years 2 months ago by Mrsmackpaul.
- Mrsmackpaul
5 years 2 months ago #219564
I quickly turned both tanks off and got some big blocks of wood ready to jerry cans etc on while I drained the tank
With the aid of the Princesses thumb I put all the fuel from one tank into the other and removed the tank
The next day I vented the tank with a air line dangling in it and and going flat out and after at a guess 10 minutes started welding up the hole and all the other holes that appeared while I welded this one up
I then refitted the tank and no leaks
The airline finally arrived, I wont lie, I had given up hope of ever seeing it but apparently it was coming after all
So have changed some lines for the gear stick and removed at a guess half a dozen joiners with just 4 or maybe 5 meters of airline
There is still a air leak behind the dash so I will tackle that today and call it done, hopefully
Those of you that can remember back far enough I said this would only take a week or so, well some times things get out of hand and I have left quite a lot of small stuff out of here
Like removing the grease plate and repairing the grease lines
Replacing the power steering seals and pulling it apart, because I'm so useless that took me a day just to get the new seal over the step on the shaft with out it catching
Adjusting linkages better.
Fixing all manner of little things along the way
But also note I said Miss Molly the border collie and I are going to........
Well apparently hunting rabbits and sleeping and been a dog is far more important than helping me
She really needs to have a good look at herself as just been a dog isnt really helping me lol
So clearly she is to blame for the over run on time
- Mrsmackpaul
5 years 2 months ago #219565
Well its been so long I forgot this bit
I did pull the lid and air rams completely apart to be as far as I can be 100% sure that everything is ok in there and it was
The real challenge is getting the lid back on
So those few things took a full day to achiece
The autopro shop in town love me at the moment buying stuff at a unprecedented rate
So I ended up getting a mirror on a stick and a thin LED torch and insulation tape and a piece of fencing wire to just get the lid to sit back on correctly
I have no idea how I ever did this on the side of the road once
I was much younger and more flexible I think
And the tired out worker, I mean I'm up, whats the story with you girl ?
Mrsmackpaul wrote: It's a bit of stuffing around pulling the lid on the transmission but easier than pulling a fuel tank off and dropping the box out
So once the seats and the special custom floor was opened up it didn't take long to pressure clean the top and lift the lid off, it will take considerably longer to get the lid back on
Any how, the bolts were all still tight and the oil pumping compressor was the cause and my poor maintenance has forced the issue
Time to create page: 0.404 seconds
