- Thank you received: 4418
Mrs Mack
- Mrsmackpaul
- Thank you received: 7851
4 years 11 months ago #218812
Replied by Mrsmackpaul on topic Mrs Mack
Well just to satisfy people's curiosity I had a look at the brake shoes and they were as I thought they would be, all the same numbers
One half has CAM stamped on it the other has ANC stamped on it
This is the two separate pads on the same shoe
CAM goes on the S cam end and ANC goes on the fixed or anchored end
Bearings for the Tip Turbine arrived so I put it back together and checked for clearance etc, just used wheel bearing grease
The bearings are side load roller bearings, not a standard ball bearing, more like a thrust bearing so I put them in facing each other
It's all spring loaded and shimmed etc so took some creative thinking to make this all work
Next was the front hubs as the seals had turned up as well
Now Les and Vern (if you ever watched my YouTube videos you will know who I'm talking about) had taken the nuts with a hammer and chisel so I welded the nuts up and ground them back to shape
- Mrsmackpaul
4 years 11 months ago - 4 years 11 months ago #218895
Was advised to just make a spanner instead of buying a socket by Swishman, so thats what I did
I started with this
Yeah a beaut sunrise, I really do think this is the greatest country on earth
Got some rusty crap inch x 1/4 flat bar, put some relief cuts on what was to be the outside and slowly bent it around the nut and welded it up
Then got a even crappier piece of 2 1/2 inch pipe and welded it to the flat pieces
And I ended up looking like this
I then welded a bit of 2 or 3 mm plate to the end and drilled a 20 mm hole in the end and one thru each side
The end one I took to with the file to make it square to fit a 3/4 drive ratchet
The end ones I put encase I want to stick a bar in it
I then welded a bit of 3/8 reo around the very end just encase the strength of my saggy old body is to much and busts it
Ended up looking a little like this
I started with this
Last edit: 4 years 11 months ago by Mrsmackpaul.
- Mrsmackpaul
4 years 11 months ago #218896
So next was to try it out and it worked as expected
Front wheels are back on
So gear box time tomorrow
4 years 10 months ago #218909
Your "chair" looks a bit more comfortable than a milk crate. Is it?
Nice work on the socket, btw.
- Mrsmackpaul
4 years 10 months ago #218912
Jarrod its like a big air cushion and yes much better than a milk crate
4 years 10 months ago #218918
Thats a postcard pic of a sunrise, well done.
The socket will last longer than a genuine one, very well built.
4 years 10 months ago #218924
by werkhorse
Paul, when I was on the spanners... Most of my work was brakes, hubs etc. We made all our "spanners" just like you did...
I've watched this part of the thread with a bit of a chuckle... For the fact that that it's exactly how I remember/d I d it.... And the fact that I don't do it anymore
Time to create page: 0.367 seconds
