- Thank you received: 58
Spread axle trailers
13 years 8 months ago #32791
by jimbo51
Replied by jimbo51 on topic Re: Spread axle trailers
13 years 8 months ago #32792
Jimbo
GuddayM8
Jeezuz talkn bout a mobile carpark
Gr8 Pix
Keep m Cummin
Gr8 effort by Fin
a duzen cars n not small cars
RE:trailer would be a Pig in Oz terminology.
May B also a Tag trailer
can remember way back when
'B dubles hit the rd
the rush twaz on to get a car carrier B
forgot hoo twaz 1st they got 9 cars on the 1st V: of the B setup
ButEyeDOSt&2BCorrected
[ch9787]
Replied by Swishy on topic Re: Spread axle trailers
Jimbo
GuddayM8
Gr8 Pix
Keep m Cummin
Gr8 effort by Fin
[ch9787]
13 years 8 months ago #32793
by jimbo51
Back in about 1988 Finemores designed and built their version of a Stinger to take advantage of the newly available B Double overall length which was initially 21.5 metre I think.
This was also a rigid plus pig but it used a unique linkage that pivoted horizontally where it was attached at the rear of the prime mover chassis and vertically where attached to the trailer.
Unlike a fifth wheel where the two axis' of rotation are coincident, in this linkage they were separated by about a metre. From memory this was necessary to achieve load clearance during turns while still being coupled close enough to remain in the overall length. Even then there were challenges with rear overhang.
As designed it could carry 10 cars. But then conventional B-doubles car carriers appeared when the overall limit lenth was extended and they could carry 5 cars per trailer plus one on the overhead for 11 in total.
I think those first B-doubles were built by Topstart and operated by TDG (originally Arnolds and Shields and ultimately Patrick Autocare).
As usual, subject to memory limitations and open to correction.
13 years 8 months ago #32794
Replied by on topic Re: Spread axle trailers
Swishy
The d'angelo unit will make a good grill ornament for any car that runs into it when running with no trailer.
Trevor
Trevor
13 years 8 months ago #32795
Slos Peed
GuddayM8
RE: make a good grill ornament for any car that runs into it when running with no trailer.
n when the car runs into rear of truck
the car driver would blame the truck driver for backin into m
[ch9787]
Slos Peed
GuddayM8
[ch9787]
13 years 8 months ago #32796
by oldfulla
Replied by oldfulla on topic Re: Spread axle trailers
Swishy
While I will stand correcting on this - but I think the difference between a PIG trailer and a TAG is - that a pig was/is something with a self supporting suspension (2 or more axles) and a hinged, non load bearing draw bar. No trailer weight is shared by the towing vehicle and is towable with a ringfeeder or similar.
A tag trailer has a load bearing draw system (sharing weight with the hauling vehicle) requiring a Barteltt Ball or under slung turntale, or similar.
Therefore (in my books) that makes the 'Stinger' car carrier trailers a Tag - not a Pig.
I believe the 'pig' name came from them usully being a 'heavy, short (due to the self supporting suspension bit), and dummpy' thing. The Stinger was probably better called a 'grader' due to the fact they bellyed out on minor humps.
As I said up front (get out of jail clause) - I will stand correcting.
Oldfulla
Oldfulla
13 years 8 months ago - 13 years 8 months ago #32797
by jimbo51
I'd understood the opposite to Oldfulla - that a pig had a fixed drawbar, a single axle or group and required a Bartlett ball or underslung turntable. That is per Swishy's original definition and seems more in line with the State Transport Departments definition.
Also that a tag was a more generic term for any trailer following another as in a B-double A and B trailer being lead and tag.
Maybe it's a regional thing, like in Victoria a scallop is a shell fish and in NSW it's a potato cake and like Queenslanders call XXXX beer and Victorians call it p***!
Last edit: 13 years 8 months ago by jimbo51.
13 years 8 months ago #32798
Interestin topic
Ol fulla
GuddayM8
SORRY
But I'm with Jimbo on this
So when U go past go
= No Beer money
U lost me again when U said
"something with a self supporting suspension"
I dont getcha drift there?
me thinks a pig is a solid constructed drabar th@ dont hinge with only one turning point @ the Bartlett (Wotever) th@ throws weight on to truck
sum cattle trucks have a pig with a sliding draw bar
so they can shortn up to put each cattle body against each other with inline gates for easy loadn of the beasts, n easy backn of the pig coz itz only got one turning point where az a dog trailer has 2 turning points if U cant lok the drawbar in the straight position
http://www.tcimages.net/DisplayImage.aspx?PD=22315817&S=ISS&wmin=truckhub
http://www.tcimages.net/DisplayImage.aspx?PD=21844342&S=ISS&wmin=truckhub
http://www.tcimages.net/DisplayImage.aspx?PD=20248480&S=ISS&wmin=truckhub
I'm still not sure wot U call them stag trailers of Lusty
Is it a:
Tag,Pig or rear of a 'B Duble'?
A 'B duble me thort twaz supported by a 5th wheel center or forward of the rear suspensiom center
RE: Queenslanders call XXXX beer and Victorians call it p***!
A beer iz a beer in any language
but a cold cold beer is delightfull
n I'll drink 2 th@!
[ch9787]
Interestin topic
Ol fulla
GuddayM8
SORRY
= No Beer money
Is it a:
n I'll drink 2 th@!
[ch9787]
13 years 8 months ago #32799
Replied by bigcam on topic Re: Spread axle trailers
The way all the staes define them is, Fixed Drawbar, weather it's a 6X4 box trailer or a Tri Axle tag machinery trailer is called a Pig. Hinged Drawbar with a ball race is a Dog. If it's got a Quick Release turntable on it, and it's under a trailer, you need to register the dolly and the trailer. The Stag trailer is a B double. If you look at the rego forms for every state, they are the same in the definitions.
Time to create page: 0.472 seconds
