- Thank you received: 80
Re: Chassis number locations -put them in here
3 years 6 months ago - 3 years 6 months ago #215906
by Eightpot
Also on a brass plate on top of the radiator scuttle in the cab just behind the centre windscreen pillar. This also contains original engine number and differential ratio. Can also be found on the nearside (LH) top edge of the gearbox by the side cover plate. This not an infallible guide as gearboxes can get swapped.
Replied by Eightpot on topic Re: Chassis number locations -put them in here
oldbob70 wrote: G`Day gents
Foden --Above rear spring hanger on first steering axle can be either side of chassis. Often under hoist mounting.
A copy of factory Build sheets is avaiable from Chester Museum in the UK.
Oldbob
Last edit: 3 years 6 months ago by Gryphon.
Time to create page: 0.378 seconds
