- Thank you received: 81
359 dodge truck build
- Tassie Dan
2 years 11 months ago #221955
by Tassie Dan
Replied by Tassie Dan on topic 359 dodge truck build
I hear you John, I am struggling to walk away from Margo when I park her near people feeling proud and cool cos I am a bit nervous that she will piddle a bit of coolant out and make a mess. Thank you everyone as always, your advice is away appreciated. I will clean it coolant system out this weekend and thinking I will fit a thero fan and catch can too while I am at it.
2 years 11 months ago #221956
Replied by Swishy on topic 359 dodge truck build
TD
Gudday m8
FWIW
When water is heated it expands
th@'s why when U look down the neck of the radiator after a run when it reached normal water temp and then cools
U can C the water level a cupla inches down the neck of filler
the idea of a pressure radiator cap is to dump excess water
unless U B runnin a header tank where it can push the hot water out of radiator to header tank n suk it back in as it cools
Guys Correct me ifn rong ........ again
Gudday m8
FWIW
- Tassie Dan
2 years 11 months ago #221958
by Tassie Dan
That’s what I have always thought too swishy. I was just getting confused, last car I built without a header tank or over flow was my LJ Torana, everything since then I have had either overflow tanks on the rotaries I have built or factory header tanks.
- Thank you received: 1119
2 years 11 months ago #221960
by oliver1950
You can't have too many toys!
Replied by oliver1950 on topic 359 dodge truck build
Swishy is right Yours would be the old system.
The following user(s) said Thank You: Tassie Dan
2 years 11 months ago #221969
by wee-allis
Replied by wee-allis on topic 359 dodge truck build
Dan, the early system, like yours had a pressure cap used to raise the boiling point of the coolant. The cap had just one seal, at the bottom where it contacted the neck of the radiator. It allowed excess water out as needed but only sucked air in as it cooled.
The sealed system with an overflow tank has an extra seal under the top of the cap to prevent air being drawn in, causing coolant to be returned from the overflow. If you want to fit an external tank, you should have no trouble getting the cap to suit.
In saying all of the above. just top it up before you go and if it doesn't overheat, don't worry about a little dribble. It happens to the best of us as we get older.
2 years 11 months ago #221973
Replied by cobbadog on topic 359 dodge truck build
Sounds like a life experience "dont worry about a little dribble". :woohoo:
- Tassie Dan
2 years 11 months ago - 2 years 11 months ago #221986
by Tassie Dan
Last edit: 2 years 11 months ago by IHScout.
2 years 11 months ago #221995
by roKWiz
Heritage Stonemason
Replied by roKWiz on topic 359 dodge truck build
Love the fact its on full rego.
Heritage Stonemason
2 years 11 months ago #221996
by werkhorse
Can't beat a good crisp Tassie morning.... We're getting - 2 in the morning and - 3 Sunday mornings here in Launceston....
Replied by werkhorse on topic 359 dodge truck build
Got to love fresh mornings
