- Thank you received: 3007
359 dodge truck build
2 years 10 months ago #222027
Replied by cobbadog on topic 359 dodge truck build
''Practise makes perfect'' or so they say. At least it is an easy fix and a cheap one too. When I had access to the timing mark pointer I always put a dab of white paint on it and in the notch on the balancer for easy reading at a later date. If the seal is just a straight forward oil seal then also closely inspect the condition of the pulley and where the seal runs. Look for any grooves as it should be nice and flat. If there is a slight groove buy a speedi-sleeve and fit that too. Very easy to fit and worth every cent to ensure a good seal. (pun intended).
The following user(s) said Thank You: Tassie Dan
2 years 10 months ago #222035
by 600Dodge
Replied by 600Dodge on topic 359 dodge truck build
You can do the seal with the cover still on the engine unless you really want to pull it off again.
- Tassie Dan
- Thank you received: 81
2 years 10 months ago - 2 years 10 months ago #222438
by Tassie Dan
Replied by Tassie Dan on topic 359 dodge truck build
Last edit: 2 years 10 months ago by IHScout.
- Tassie Dan
2 years 10 months ago #222439
by Tassie Dan
Not sure if the video will work or not sorry.
- Tassie Dan
2 years 10 months ago #222440
by Tassie Dan
Nope, sorry. Didn’t work
2 years 10 months ago #222445
I hoped that your Dad had something on especccccially if there is a video of it all!
My way of posting a video is to post it on YouTube then post the link. This maybe a 19th century way of doing it but it works in my head.
2 years 10 months ago - 2 years 10 months ago #222448
Replied by hayseed on topic 359 dodge truck build
TassieDan, Send either Gryphon or IHscout a PM they will be able to Help with the Video, forum@hcvc.com.au
Last edit: 2 years 10 months ago by Gryphon.
- Tassie Dan
2 years 8 months ago #224247
by Tassie Dan
Hello there. Thinking I will never cart 3 tonne on tray so I am playing with the idea of getting some leafs taken out of the spring packs to both lower her a bit and make her a little bit nicer to ride in. I don’t have the tools to really do it safely so I will take it to a work shop but is this a silly idea, will it make much of a difference?
- Thank you received: 4733
2 years 8 months ago #224248
Replied by Mrsmackpaul on topic 359 dodge truck build
It will make a huge difference
And no it isn't a silly idea at all, will no doubt make it much more enjoyable to drive about in with no load on it
- Tassie Dan
2 years 8 months ago - 2 years 8 months ago #224298
by Tassie Dan
Last edit: 2 years 8 months ago by IHScout.
Time to create page: 0.586 seconds
