- Thank you received: 1695
heggie's transport
1 year 9 months ago #237597
by xspanrman
Replied by xspanrman on topic heggie's transport
1 year 2 months ago #243985
by xspanrman
THEN and NOW! Heggie's fleet number 363 found.
Chassis Number402916. 1978 L-HD Kenworth has spent most of the last 40 years in a shed and not worked. This was the trial truck before Heggie's purchased about another 8. Spec sheet showed it was originally a 15 speed Roadranger but it must have been changed to a 9 speed at the dealers. The current owner pealed back the 9 speed gearshift pattern sticker and found a 15 speed pattern sticker underneath. The current owner plans to get the KW roadworthy and fit a small tray body on it to move his tractors around..
The following user(s) said Thank You: 180wannabe, cobbadog, Inter-Action, Lang, Mrsmackpaul, overlander, PaulFH, asw120, Tacho, wee-allis and 2 other people also said thanks.
- Thank you received: 4758
1 year 2 months ago #244021
Replied by Mrsmackpaul on topic heggie's transport
That's quite the amazing find, I gather it's very low mileage then
1 year 2 months ago - 1 year 2 months ago #244028
by xspanrman
Speedo reading 712,076 klms Air cleaner last changed 639545 klms 2-5-83, probably 1 to 2 years before Heggie's sold that truck.That's quite the amazing find, I gather it's very low mileage then
Last edit: 1 year 2 months ago by xspanrman.
1 year 2 months ago - 1 year 1 month ago #244031
by xspanrman
This truck was built with a 15 Speed Roadranger and changed to a RT9509 Roadranger and 38,000 lb Eaton diffs. After the disaster with the first 6 W models 38.000 lbs diffs which had all diffs replaced with Rockwell 44,000lb, I am sure all the later L-HD's KW's came with Rockwell SSHD 44,000 lb diffs. A question for the brain's trust? The diff in the photo 38,000lb or 44,000lb? The 44,000 lb Rockwells I worked on had a pressed metal cover on the input shaft to hold the seal, not a cast housing.
Last edit: 1 year 1 month ago by xspanrman.
The following user(s) said Thank You: PaulFH, oliver1950
- Thank you received: 839
1 year 2 months ago #244042
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic heggie's transport
I think i will go with a 44.................
...............Billy................
1 year 2 months ago #244044
Replied by hayseed on topic heggie's transport
Me Too, Billy.
1 year 2 months ago #244055
That to me seams like a lot of miles in a short amount of time on what I would of thought to be short haul type of work
Did these trucks run 24 hours a day ?
1 year 2 months ago #244056
Paul, 72,531Km's won't take long at all to rack up....!!
Time to create page: 0.558 seconds
