Well long story short
The oats went passed hay while we were standing watching so we decided to strip the oats for seed
So the old Massy Ferguson 585 header was decided to be the said tool for the job
Has a 4 pot Perkins, looks to my eyes like a 6354 only shorter
So been Perkins Im feeling confident it will fire right up
Turns out it has been over 10 years since it has seen action and it has other ideas
Well we have fuel getting to the injector pump but not coming out the other side
So we pop the top off the pump and find the metering valve stuck
No problem, chuck it all back together, still no go
So we lift the lid and look again to make sure the hook is lined with the stopper pin, it all looks good but no luck at all
So we pull the head to make sure the transfer pump is ok and the filter, springs and little piston doohickie are all fine
They all look good so we put it all back together and try again and discover theres no fuel getting to the injectors at all
So we pull the injector pump off the headet and open it and delve deeper into the unknown than I have ever ventured before
We pull it completely apart on the bench and make sure its clean and the bill hook is back in the correct position under the lid as none of this can be seen when its on the header
We reassemble this all and it's still not pumping
Time for a cuppa and a quick Google and I find the picture shown
I reckon I know what the problem is, I reckon the pump plungers number 9 are gumbed up and stuck
So apart with it all again , we take a few photos so we can return all the parts exactly as they came out
We found both plungers stuck and soon freed them up taking extra care not to scratch anything or even leave a mark
Put it all back together and tested it on the bench and found it now pumped and when we pulled the stop lever it stopped pumping and started again when released
So put it all back on the header, primed it up and soon had diesel coming out the injector lines
And by my untrained eye we had heaps of fuel
So nip the injectors up and nothing, no smoke, nothing at all
So maybe the injectors are gumbed up as well, so we pull them and find they are all fine and their plungers are free as
So we reinstall the injectors upside down and there is no spray, no leak, no dribble nothing at all
So we have heaps of fuel getting to them and just not enough pressure
Does anyone have any ideas ?
