- Thank you received: 323
Kenny roof mount air intakes
10 years 9 months ago #148990
Replied by on topic Re: Kenny roof mount air intakes
...that pic of the early Transwest 8X4 shows the intake up beside the aircon...they must've moved 'em outboard at a later date....
10 years 9 months ago #148991
by jeffo
Replied by jeffo on topic Re: Kenny roof mount air intakes
The other concern was exhaust soot, another reason to separate intake and exhaust as far as possible.
Not too many Inter Transtars stayed with the factory arrangement which looked good, but was very prone to ingesting exhaust fumes.
10 years 9 months ago #148992
...i s'pose the inboard mounted air intakes had to be moved eventually as the inception of the roof airfoil became a more accepted thing...
...jeeez .. they crammed a few things up there for a while!...
- Thank you received: 52
10 years 9 months ago #148993
by grumpy
Replied by grumpy on topic Re: Kenny roof mount air intakes
SPOT ON DETECTA
Finemores had the first KW to have a factory fitted air-foil. It had the standard air intake up the back of the cab. There was a noticeable effect and also unusual air intake resonance during the road test. Engineering got straight onto the problem and went for an air intake design that was used on trucks that were specced for heavy/extreme duty. From memory, all trucks built at that stage, for heavy/extreme duty or road train work, had the forward mounted air intakes.
10 years 9 months ago #148994
by dieseldog
Replied by dieseldog on topic Re: Kenny roof mount air intakes
I always thought that it was simply because the air was cleanest coming straight off the windscreen.
The air swirling behind the cab would have brought the dust up from the front wheels, through the chassis and straight into the standard air intakes.
10 years 9 months ago #148995
Replied by Swishy on topic Re: Kenny roof mount air intakes
Twaz a Bulletin many years ago from KW about all cabs will have a HD reinforced cab roof
frame to mount all D stuff uptop az the fibre glass needed back up n support
IfnU get my drift
IfnU get my drift
10 years 9 months ago #148996
by grumpy
Even though the air intake cleared the cab roof, there was still an updraft caused from the back of the cab.
Those cabs weren't very aerodynamic, so there must have been a low pressure area there somewhere behind the cab that would suck in all the dust and crap. Also if the rubber seal doo-hickey at the top of the air cleaner housing was a bit suss, they would suck in a lot of crap thrown up off the road.
A lot of guys used to complain about the position of the air cleaner housing too ... right behind the RHS front wheel.
First attempt at the roof reinforcing were a couple of bits of RHS fibre-glassed to the underside of the roof, not real big in size, coz if it was, the roof lining wouldn't fit.
They did the same reinforcing when they fitted the old style Kysor roof mounted AC's too. Hey Phil .... were the Peterbilt cab roofs reinforced for the AC unit too?
10 years 9 months ago #148997
...hey Grumpy .. as part of the aluminium roof structure of those mid sixties Petes, there were two longitudinal extrusions that were part of the original design riveted to the underside of the roof top sheet...
....these lined up directly with the four bolt mounts for the Kysor...and a few other aircon types i guess....
10 years 9 months ago #148998
by andy950
Replied by andy950 on topic Re: Kenny roof mount air intakes
just made and fitted a set to my K100e last weekend, get some pics up when I can
10 years 9 months ago #148999
Replied by geoffb on topic Re: Kenny roof mount air intakes
Reckon the Areo's with them up the sides look great
Time to create page: 0.298 seconds
