- Thank you received: 2512
2 stroke GM Detroit diesel .......... History
5 years 5 months ago #213875
Replied by JOHN.K. on topic 2 stroke GM Detroit diesel .......... History
The last 71 s had spring loaded levers on the rack so one stuck injector couldnt jam the rack...........Ive also seen the same problem on a D9G.....no rack ,but water in the oil caused the small pilot valve governor to stick .Fortunately the intake pipes were off ,and a bit of flat board stopped the motor running away.
5 years 5 months ago #213876
Replied by Swishy on topic 2 stroke GM Detroit diesel .......... History
Wot so special about the screemin 2 stroke GM Detroit inlet valves
LOL:lol: :side: :evil: :whistle:
- Thank you received: 582
5 years 5 months ago #213881
Replied by Blackduck59 on topic 2 stroke GM Detroit diesel .......... History
Had a 12V71 take off one night, the governor drive had worn /broken and not being able to sense the RPM applied full throttle with no governor action to back it off.
5 years 5 months ago #213884
Never pulled the shutoff flap meself ........legend has it that the blower will seize the paddles .........once saw a NSWGR Clyde loco have the shutdown applied ....couldnt see for smoke ,but the motor kept idling at about 50 rpms.
- Thank you received: 893
5 years 5 months ago #213885
by BillyP
I believe china is waiting for the specs so they can make them ................
................Billy....................
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic 2 stroke GM Detroit diesel .......... History
Swishy wrote: Wot so special about the screemin 2 stroke GM Detroit inlet valves
- Rattail 1927
- Thank you received: 66
5 years 4 months ago #214134
by Rattail 1927
Replied by Rattail 1927 on topic 2 stroke GM Detroit diesel .......... History
When they ran away they jump the racks and if you pushed on the accelerator pedal that made them worse , ?? Is that right I had been told it one night by a Gm 2 stroke lover, but I’m not sure I got it right, can someone tell me please
5 years 4 months ago #214138
Have not heard that before, pretty well impossible to "jump"the rack.
If it is a runaway from the rack it is usually a stuck injector with the old double screw rack arms.
Now if you have had the top off the governor and not put it back on correctly you can get a runaway.
5 years 4 months ago #214141
Most common disaster with a GM is leaking fuel jumper ,rod thru the block .....used to happen regularly with Austin Western cranes with 4/53s,dunno why.
5 years 4 months ago #214155
by BillyP
A little GM question ...............If you had , ... lets say a 671 .... .... relative to the crankshaft, what direction
would the camshaft rotate..........................................
.......................Billy.......................
5 years 4 months ago - 5 years 4 months ago #214157
Depends which rotation and camshaft.
If you go back to the second of those video clips, about 1:55 there is a schematic for left and right hand engines
Last edit: 5 years 4 months ago by Blackduck59.
Time to create page: 0.311 seconds
