Aussie Refuse Trucks
I actualy got hold of the Acco before it was used as a garbage truck, it was the engineering test truck for the Hendrickson airtek airbag front end, it only had 600hrs and 19,000k's on it.I just converted a dual control Acco garbage spec c/chassis to normal control and fitted a tipper body.
It was the 1st Acco to have the Hendrickson Air tek front air bag suspension.
All garbage spec Acco's come down the production with pre drilled chassis to suit different compactor body manufacturers.
Mine is a Macdonald Johnson spec (MJE), Superior Pak and JJ Richards are all different.
Iveco really go out of their way to help the body builders and I am suprised at how well the later Acco's drive, it's quieter inside than my little Mack and really well built.
And light years better than my old 2670.
That's a phenomenal job you did with converting that ACCO G from dual control to right hand side drive. Looks like as if Iveco built as a right hand drive. It's amazing how that truck was once doing a residential garbage collection route, now it's on tipper duties. The uses for ACCO's is endless, goes to show that their a great truck. The newer ACCO's are fabulous, the Cummins ISL engine gives the ACCO a competitive upper hand advantage, against the other brands.
That's once nice looking T2670 you got, guessing it was built in the late 80's- early 90's? .
I sold my old T Line about 4 years ago, it was a L10 300hp, 15 direct on 4.11's, 1988 Model....tough as nails that truck, I replaced it with a 2007 Mack Metroliner 8x4.
Beaver@ Museum of Fire
1980 Leyland Mastiff 540&&1942 V8 Ford Jailbar 3 Ton&&1982 Volkswagen Kombi Transpor
Cheers!
Transpacific are not my favourite company as they are extremely bad payers and still owe me money for some work I did on one of their phone systems many months ago.
I don't know if you are aware that Superior Pak are one of their subsidiaries. I've noticed a few JJ Richards trucks with Superior Pak bodies.
Early reports are that the Dennis Sideloaders are not coping well with our high temperatures and crap roads. The cabs are like glass houses and the aircon is useless because the drivers keep the left hand windows down when picking the bins up.
Where as the acco cabs don't get any where near as hot.
-They both have Cummins ISL engines and both have Alison Auto transmission.
I loath transpacific cleanaway, worst waste company ever! >
