- Thank you received: 4737
3 years 11 months ago #209719
We stopped using it on lifts because some of the chemicals in it were believed to cause cancer
Caused a hell of a stink back in the day as we had nothing else suitable to replace it
Im guessing either it wasnt as bad as was thought or the mixture has been changed
3 years 11 months ago #209747
Been soaking the injector to get it apart then cleaned. I have the top section and that needle out and free but the bottom one is rock solid. It has been in some thinners for a few days and the 2 hoes in the injector cap are now clear and the cavity behind is clear so the thinners is working from both sides now.
Looks good for the oil primer from a member here, so thank you for that. I need a few dimensions for a fuel tank and although I have the cast iron casting for the air cleaner I am after the outer housing if one is king about please.
I will have a go at using my ultrasonic tank to try and free this bugga up but the thinners is slowly working it's way in.
3 years 11 months ago #209751
Replied by Swishy on topic McDonald Imperial Super-Diesel
put the buggr in mums oven
heat let cool then bung it in the freezer
do it a few times .... may take a day or 2
wen its heated melt some candle wax on the area th@ aint co operate n
wen it cools it draws the candle/paraffan wax in
The following user(s) said Thank You: cobbadog, oliver1950
3 years 11 months ago #209753
Rather than risking a sudden case of "DEATH" I will leave the oven alone and use the big bunsen burner if I need to.
Thanks for the idea though.
3 years 11 months ago #209754
Replied by Lang on topic McDonald Imperial Super-Diesel
Good move Cobba. When I was a pup I repaired a leaking header tank on my E-Type with araldite. To speed the process I put it in my future mother-in-law's oven. On completion the entire oven and racks were covered in a stinking tar like substance from whatever coating Jaguar used on their radiators.
I can't think of the right word - berserk is too mild. Although the marriage went ahead my relationship with Poppy never fully recovered from the disaster.
DON'T DO IT!
DON'T DO IT!
3 years 11 months ago #209755
OK then
if n U aint in Mums good books
boil sum water ( a slow gentle heat with the mongrel beast in the water from cold)
probly after mothers day U shood B in the good books
UWish
UWish
3 years 11 months ago #209762
Brake cleaner seams to work better than thinners I reckon
But a pot on BBQ full of water might keep you in the good books
3 years 11 months ago #209772
I do know that in the oven it will not go. The boiling water trick is yet another idea to add to my lists of plans but if I light the BBQ I'm sure it would be an indication that I intend to do the cooking at some point soon, no thanks. Again a tin with water and the bunsen burner sounds safe enough for me.
A saying quite often said by a mate was;
I wear the pants in this family and I will come out from under the bed when I am ready.
3 years 11 months ago #209831
I had a bit of time to play today and started with the big bunsen burner to heat up the cast housing and maybe help release more crap or even the needle. It proved to be interesting with a bit of heat soon it ignited some crap inside the cap and a pair of flames were shooting out. It burnt for a while and at the same time smoke was coming out the top end like a chimney. I have made a tool to lightly drive onto the top of the needle which in turns grips it and I hoped it would then lift the needle out, not yet. But I did find what appeared to be grease inside now after the heat and burn out. It has not let go as yet but tomorrow is another day as a customer rang me and was in the deep poo stuff again so he turned up and I had to fix his problems and that was the end of play time.
3 years 11 months ago - 3 years 11 months ago #209841
It's a disease we suffer from cobbadog, a disease! :sick: :pinch: :whistle:
Last edit: 3 years 11 months ago by PDU.
Time to create page: 0.493 seconds
