- Thank you received: 4714
1938 Fargo Pickup.
3 years 4 months ago #217423
Replied by Mrsmackpaul on topic 1938 Fargo Pickup.
They still use that type of dohickie today for pulling wires, we call them a sock and like that it is slipped on, when pushed its all loose but when pulled it tightens and grips the cable
3 years 4 months ago #217436
by someguy
Replied by someguy on topic 1938 Fargo Pickup.
You're right Mrsmackpaul, They are like a steel mesh tube that grips tighter the tighter you pull.
3 years 3 months ago #218036
by someguy
Well the wiring still isn't here so I decided to keep cleaning up more diseased and mouse nest infested parts.
One of them was the heater. The truck will see winter driving, so around these parts the heater will be needed.
3 years 3 months ago #218037
by someguy
After a couple hours of soldering due to what looks like the heater core froze and cracked the tanks and pulled apart the seams.
I pressure tested it and it seems to be fine!
3 years 3 months ago #218038
by someguy
3 years 3 months ago #218040
That has come up better than new
The following user(s) said Thank You: someguy
3 years 3 months ago #218044
by IHScout
Dennis
Replied by IHScout on topic 1938 Fargo Pickup.
Love your work. Am I right in thinking the heater inlet/outlet pipes also act as mounting bolts for the heater. That's some pretty good design thinking if they do.
Dennis
3 years 3 months ago #218079
by someguy
Yes you are right, the pipe is actually steel and just threaded a bout 4" or so.
I reused the original mounting hardware and just added a rubber buffer pad behind the washers.
You just slide the hoses over the threaded part and clamp them down and they seal up well.
Time to create page: 0.536 seconds
