- Thank you received: 15
Diamond Reo cab over
4 years 5 months ago #218049
by Tambox
Replied by Tambox on topic Diamond Reo cab over
Started instantly
Will till cab back, clean it and see if I can make it move itself.
The range selector has Eaton moulded into it, DIR/OD.
Knob says fuller roadrunner, L,R,1-4, 5-8.
Also has a low/ high selector clamped to gear lever.
4 years 5 months ago #218053
by Tambox
4 years 5 months ago - 4 years 5 months ago #218059
by Tambox
It drives, gears change well.
Drives just like a 70s truck, with no power steering and flat front tyres, working on that.
No air or brakes yet, there is a valve under the driver that sticks, will try and free it up.
Yes I will sell it.
Yes I will sell it.
Last edit: 4 years 5 months ago by Tambox.
4 years 5 months ago #218060
by ralph
Replied by ralph on topic Diamond Reo cab over
13 speed r/r
- Thank you received: 6937
4 years 5 months ago #218061
Replied by Mrsmackpaul on topic Diamond Reo cab over
Your making progress
4 years 5 months ago - 4 years 5 months ago #218063
by Tambox
The brake valve is bleeding air.
Is there an easy way to connect my shed compressor to pump up the truck air, save having the motor running/starting stopping.
Thanks for the feedback, I am understanding the truck much better now.
4 years 5 months ago #218064
Replied by asw120 on topic Diamond Reo cab over
If that's T1020, your truck is only 4 before mine (if I'm remembering the number right).
Good that it's going.
Brocky: yes, Aussie cab. Only for a couple of years until Road Commander cab came out.
4 years 5 months ago #218091
by Tambox
Could anybody suggest where I can get an E3 foot valve.
Either in Gippsland or somewhere with a reliable delivery service.
Thanks Greg.
Thanks Greg.
4 years 5 months ago #218092
Replied by Swishy on topic Diamond Reo cab over
m80
most truck sales/parts can get the E3 in 4 U
could try
Multispares
Truckline
SCT&T
all in dandy
ring 1st coz if they haven't got it on the shelf they will get it in 4 U
also there may B a newer update V:
could try
Multispares
Truckline
SCT&T
all in dandy
4 years 5 months ago #218094
Replied by mammoth on topic Diamond Reo cab over
For a quick fix of a leaking treadle valve drop some CRC or similar into the air compressor intake. worked for me.
Time to create page: 0.312 seconds
