10 years 10 months ago - 10 years 10 months ago #57016
Replied by on topic Re: Preparing & Painting a 1927 Inter Chassis
Tank is now all clean inside, need to strip the paint from the outside.
Had to do a bit of a run out to the sticks (Monbulk) on Friday to pick up a little load for Choc's so picked up my parts on the way, exhaust manifold has been ceramic coated at www.modernplating.com.au , new distributer ready to go in from www.performanceignition.com.au also been fixing up the fuel gauge had the local trophy place engrave a new face for the gauge.
Trevor
Trevor
10 years 10 months ago #57017
Come on Trev spill the beans whats happening with the tank ??. Dave
10 years 10 months ago #57018
Double D
Had a little set back with needing to change the gearbox in the tilt tray.
Tank is now all clean inside and out so if its not raining later will throw in the rust converter/etch once this is done need to rinse it out several times, let it dry completely then I can put the sealer in so Slo lee getting it done. Ross came around and re did the engine paint so manifold and dizzy can go back on, still waiting for carby.
Next outing is echuca so still got a bit of time.
Trevor
Trevor
10 years 9 months ago #57019
Finished sealing the tank and boy does this stuff stick like s#it to a blanket.
Instruction sheet supplied
Tank after final cleaning
Tank with rust converter/etch poured in the whole lot rotate it around for about 45 minutes then drain it all out (some of it comes out like beaten egg whites) then you need to rinse out several times and then dry it completely before sealing.
Tank with sealer
Wet just been poured in and rotated you pour the whole tin in and slowly rotate it making sure all side are covered for about 15 minutes then you drain it for about 1 hour, then you still need to just slowly turn it just to stop it pooling about every 15-20 minutes for the next couple off hours then let it set.
This is the finished product and it has got a shiny film all over the inside, it now needs 3-4 days before you can put any fuel in it.
Trevor
Tank with sealer
Trevor
10 years 9 months ago #57020
Didn't show it but you do have to seal/tape up the filler and drain holes before/during each step otherwise you will have this stuff everywhere. also make sure all threads etc are cleaned before this stuff goes off.
Trevor
Trevor
10 years 9 months ago #57021
by old scrapman
Replied by old scrapman on topic Re: Preparing & Painting a 1927 Inter Chassis
SloSpeed
Looks good Trevor,read the instructions the bit about putting surplus back in tin and leave to go hard with lid of or may go bang mite give one a surprise if treated like paint without thinking.
Peter
Peter
10 years 9 months ago #57022
Peter
Sure does expand up in the tin as it goes hard.
Trevor
Trevor
10 years 9 months ago #57023
So where did you the stuff used from and what does it all cost for everything ??? .Dave
10 years 9 months ago #57024
No need to answer Trev I found the info and the price $104-00 very good I will give it go in my 1936 wide body m/gardner Bedford when I get my tank back from Akipete. Dave
10 years 9 months ago #57025
Dave
Got mine from the place in Sunshine about $93 for the kit.
Link to Victorian sellers
www.kbs-coatings.com.au/vic-resellers
or
www.kbs-coatings.com.au/locate-a-kbs-coatings-reseller
Trevor
or
Trevor
Time to create page: 0.603 seconds
