- Thank you received: 2
Unless the head studs are losing their tensile strength and stretching a bit.Little more to add on the head gasket saga.
Today re checked the head tension when cold and found about half the nuts were loose again so re tensioned them. It had only run yesterday for maybe 1 hour all up and only got to about 70 deg.
Talking to Gilly today we thought it might be better to give it another run and let it cool down again, Recheck and see if the tension changes anymore.
Thinking we might have an issue with the "New old stock" gaskets I got from the states about 3 years ago. We will see what happens.
Trevor
I still suspect the headgaskets are compressing, however, IDSTBC.
Trev was going to go around the block to warm her up again today, then recheck the tensions tomorrow, so it will be interesting to see what happens.
Gilly
Thanks for the input that's what its about sharing.
Gilly
Trev reporting in. Ova
Got her up to full temp this morning then had to go to work so re checked just now. All except the 2 front LH corner bolts the rest were fine. Those 2 took about 1/8 turn.
As the studs are 1/2" 20tpi . 1/8 turn = about .006" in compression on gasket or stretch on bolts.
The first pull down yesterday was 1/4 turn on some so about .012" extra squeeze. Which I thought was quit a lot.
I will recheck them again after Echuca to see if we get anymore movement or it was just the initial heat cycle.
Trevor
Daily checks until she settles. Perhaps we should have pulled her down to 80ft lbs, :-[ would be embarrassing if we break a stud though. :
Hope she goes well this weekend.
GG
Hi trev, maybe you are squeezing out all that copper coat I put on that gasket
GG
Gilly
Mate I got a bucket underneath catching the run off.
Also think the 4 foot long pipe we used was long enough but if you want to try the 6 foot or 8 foot long one that's fine. But it could end in :'( :'( :'( :'( :'(
Trevor
Mamories :
Just an update for all who have been wondering on the head gasket.
Pulled it down to 75ft/lb and she hasn't moved thought the 60lb was a little light on but that is what I had been told it should be.
Had a new exhaust fitted during the week as we had a problem with the clutch pedal hitting the old one, got the baffled muffler replaced with a straight thru one and I recon I gained a few more horses. Still need to get a couple of spare head gaskets made and also might need to look at some manifold ones as well.
Thanks again gilly and if anyone needs some mechanical work or gas testing work done gilly is the man to contact.
Trevor
I have decided that I am going to take a break from the forum.
If anyone needs to contact me the easiest way is by email. pre30international(AT)bigpond.com
Thanks everyone
Trevor
- Thank you received: 4815
ps dont you go wearing that 27 out before I see it
