- Thank you received: 543
12 years 9 months ago - 12 years 9 months ago #56446
Replied by on topic Re: Preparing & Painting a 1927 Inter Chassis
OK have come across a problem.
? Has anyone tried to bend the brass valve steams on tubes.
The tubes that i have got have a bent valve on them that only comes out about 3/4" before it bends at 90 deg, as the tubes need to go thru the inner spider i need at least 1.5" before any bends.
Have also checked with 2 tyre places today to see if i can get some tubes with just a straight steam but no luck.
This is the tubes 7.50-20
Trevor
Trevor
12 years 9 months ago #56447
by wouldyou
Replied by wouldyou on topic Re: Preparing & Painting a 1927 Inter Chassis
Trevor, A friend here was able to straighten those valves successfully, for a similar job on a Chev four. Our Chev is at present on old tyres and we used tubes with rubber valves and screwed on extensions for length, not real good as the valves are not in the centre of the tube. David.
12 years 9 months ago #56448
Slos Peed
we have bent the tube valve stems by placing a slightly bigger pipe over the brass valve stem.......but only a minor bend like ifn U wanna straighten the the bend closest to the valve cap
U can also cut the valve off just above the exposed thread @ the tube end jist above the nut n get a screw on valve stem of your choice
May B best to Give TipTop a ringthing coz they may have travelers around melb th@ may help
REMA TIP TOP VIC
14/101-107 Wedgewood Drive
Hallam VIC 3803
PH: (03) 8786 3333
Fax: (03) 8786 3400
OR
Try Western Bandag Baldwin Rd Nth Altona
[ch9786]
Replied by Swishy on topic Re: Preparing & Painting a 1927 Inter Chassis
Slos Peed
REMA TIP TOP VIC
Hallam VIC 3803
PH: (03) 8786 3333
Fax: (03) 8786 3400
OR
[ch9786]
12 years 9 months ago #56449
by wgipps
"If I said you had a beautiful body would you take your pants off and dance around a little?&qu
Replied by wgipps on topic Re: Preparing & Painting a 1927 Inter Chassis
did you try antique tyres in Heidelberg? they are very good.
12 years 9 months ago #56450
They maybe good if you are willing to them arm & leg. Dave
12 years 9 months ago #56451
by ianoz
Replied by ianoz on topic Re: Preparing & Painting a 1927 Inter Chassis
Deadly , Its only money Better than peeing it up against the wall , And also I think Trade in human body parts is illegal .They maybe good if you are willing to them arm & leg. Dave
12 years 9 months ago #56452
Thanks
David
I might try and bend them up first as i have nothing to loose as they are no good as they are.
Swishy
Its the big bend down near the tube that i need to bend, maybe try rema & west bandag.
Wgipps
Will ring antique tyres as the prices at the 2 tyre outlets yesterday was $35 & $50 each for the wrong ones.
Dave
Sometimes it is better to pay a bit more for the correct item than waste days/weeks driving around wasting petrol and still end up with nothing.
I need 5 tubes for this truck and another 5 for the second S-24.
Trevor
David
Swishy
Wgipps
Dave
Trevor
12 years 9 months ago #56453
by Chocs
Replied by Chocs on topic Re: Preparing & Painting a 1927 Inter Chassis
Gday Trev
They will take a tweak..but usually they will break,,,some brands seem to be more of a cast brass mixture??
i have seen them re threaded with an adapter for differing applications,,
If the right ones are available, that would certainly be the way to go..
chocs
chocs
12 years 9 months ago #56454
Trevor, you won't be able to straighten the 90
12 years 9 months ago #56455
Called antique tyres today no luck they only have the same as i already have they suggested Tyre & Tube Australia (were i got mine) no luck there either they suggested Rema (Swishy's suggestion), so i have to head over that side of town on Friday so may call in and see them.
Trevor
Trevor
Time to create page: 0.573 seconds
