12 years 8 months ago #56486
Replied by on topic Re: Preparing & Painting a 1927 Inter Chassis
Bruce
Thanks for the encouragement and yes i feal as though i have achived a lot in the last 8 weeks.
I wont be cruising with you next weekend but Mum & Dad will be.
Trevor
Trevor
12 years 8 months ago #56487
Slos Peed
Look n Better by the day
RE: achived a lot in the last 8 weeks
eye'd say so
Not only do n sum inter assembly work
But also keep n the gravel n rock in production
Truble with work
it duz tend to interfere with foreigner jobs
but spsoe U need to put sum food on the table
[ch9786]
Replied by Swishy on topic Re: Preparing & Painting a 1927 Inter Chassis
Slos Peed
eye'd say so
Truble with work
[ch9786]
12 years 8 months ago #56488
by Davefarma
Replied by Davefarma on topic Re: Preparing & Painting a 1927 Inter Chassis
Hey Slo speed, great looking job your doing and its been a great thread to read, i have a question, you said you used a etch primer then a coat of 2 pack fill primer.....IM not exactly sure what this fill primer is, is this the same thing as what people refer to as spray puddy?
12 years 8 months ago #56489
Davefarma
This might help with what it is, because you can never be sure what type of paint was used before the etch primer is just a double security to make sure the rest of the paint sticks
www.hichem.com.au/hicheminfo/PIDS/Two_pack/Hpf.pdf
Swishy
The old saying no work, no money, no hobby
Trevor
Swishy
Trevor
12 years 8 months ago #56490
Engine was painted over this weekend and is now sitting back in position.
Spare sump is on the engine at the moment as still need to finalize the oil pick up before i bolt the freshly painted one on.
Its amazing how a colour changes just with or without a flash
This is the engine hanging ready to paint
Started to clean up all the fiddly engine bits getting them ready to paint along with the cowl, started to look at the body panels and will try and get them sand blasted this week so we can see if/how much work is required to repair them.
New sides have been ordered for the bonnet as one of the old ones has a large rust area on one corner.
Speedos are ready to be picked up after being repaired, headlight buckets are out being re silvered, Radiator surround for this truck should be ready this week, so work is still progressing.
Trevor
Trevor
12 years 8 months ago - 12 years 8 months ago #56491
Picked up the Speedos this week but they could not make up the cables for me as they did not have the correct ends, Might need to call on Stu's help again to machine up some ends so i can then have the cables made (just need some time to measure and draw them up).
Picked up the radiator surround from the chrome platers and after one false start and it having to be redone i am very happy with it now.
Body panels are all ready to go to the sandblaster and spent another $700 on paint supplies ready for the next painting stage. Total paint supplies cost so far and i hope this will be all of it is about $1500.
Starting to think about finish on the cab & tray dont know if i should use a urathane product or just stain it, also need to sort out any sign writing that i want on it should the signwriting be done first before the stain or urathane is applied.
Trevor
Trevor
12 years 8 months ago - 12 years 8 months ago #56492
Replied by bparo on topic Re: Preparing & Painting a 1927 Inter Chassis
Hi Trevor,
I just deck oiled mine several times (before and after assembly) as I intend to put stuff on in and walk around, loading stationary engines etc often in the rain with wet or muddy shoes on. For the same reason I didn't sand the timbers in the hope of keeping some grip.
If you use the polyurethane products similar to what is used on floorboards they can be dangerous to walk around on if it gets damp at all. Also any marks from loads will show immediately
Last edit: 12 years 8 months ago by bparo.
12 years 8 months ago #56493
Rocky
Stihl L@@kn good
Wot ever u go with az far as deck n finish
U can always have a bit of thro down /removable outdoor carpet
made up for use when cartn rock etc
Not sure wotcha got in mind
me always thort this deck lookd kool
Biggest killer is getn water BTween the joins as it will buckle up the timber
[ch9786]
Rocky
Stihl L@@kn good
[ch9786]
12 years 8 months ago #56494
Hey slo man tongue grovve is bad news in wet weather you need little gap between them planks . Dave
PS if its red leave it in the shed and the boards wont buckle.
12 years 8 months ago #56495
Slos Peed Rocky
our ol Fruehauf sem eye had timer deck n the joins
were called ship lap
it B the one on the left
[ch9786]
Slos Peed Rocky
[ch9786]
Time to create page: 0.561 seconds
