1975 Atkinson restoration
3 years 7 months ago - 3 years 7 months ago #214231
Not kno n the situation of the pin hole in the top tank
2 ruff choices
<1> Drill the hole out n tap in a sealed treaded plug
<2> thoroughly clean n blo air back in the hole to dry the pin hole then fill with JBWeld ( the yanks swear by tis stuff )
EDIT
Whoops Eye'm bad
Tap in as threaded
2 ruff choices
EDIT
Whoops Eye'm bad
Tap in as threaded
Last edit: 3 years 7 months ago by Swishy.
- Thank you received: 4715
3 years 7 months ago - 3 years 7 months ago #214232
If you dont want to fix it, as in drop the tanks off and build a fresh tank
This Deks two pack stuff will work fine
www.bunnings.com.au/deks-1l-two-part-epo...ty-compound_p4987228
Let it set as the instructions say and it will be water tight and last
However that been said, I wouldn't do that, I would just get new tanks made and a new core
Yes it will cost a few bob but will out last you if you look after
The Mack was 5 grand, the Inter tractor was 1500
The D7 Cat is next and it will be 5 grand or more
I figure if I look after these the radiators will out last me well and truly and will be cheap investment and one less worry
And if it develops a leak and I cook a motor the radiator is dirt cheap by comparison
Last edit: 3 years 7 months ago by Mrsmackpaul.
3 years 7 months ago #214233
by Oilman
Mrs Mack, I agree that I could bodgey a repair, and I might do so if I was confident that 'pin' hole was the only weak point. My worry is that if it was that thin in one place, probably that thin in many other places and murphy says it will leak when I'm a long way from home. I will pull it down, and hope that I don't have to touch the core, just make new tanks. Have done everything properly up to now, so may as well go on as I started.
3 years 7 months ago #214234
Replied by hayseed on topic 1975 Atkinson restoration
Oilman, At the very least I'd Pull both Tanks & get an old Dipstick & shove down each & every Tube, to ensure the Cores OK..
3 years 7 months ago #214246
Replied by Sarge on topic 1975 Atkinson restoration
Oilman, is your radiator one of those with individual tubes and grommets? I think we need a step by step video of the process. Please. EMNTK.
3 years 7 months ago #214250
Saw a bloke usethat steel packing strap to push through his cores once a long time ago. Fortunately for him the core was in good shape only blocked with crap so he had a good outcome.
Not sure wht the tanks are made from but maybe a brazing job will permanently fix it.
3 years 7 months ago #214255
by jeffo
Replied by jeffo on topic 1975 Atkinson restoration
From the photos, the E1 and E3 valves look very similar except for the dual circuit.
Makes me think the diaphragms etc would be the same.
Could perhaps dismantle the E3 and use it as parts for the E1 if you wanted her totally original.
3 years 7 months ago - 3 years 7 months ago #214258
by wouldyou
Replied by wouldyou on topic 1975 Atkinson restoration
The return spring from a small engine rope pull starter will straighten and be long enough for the core.
David.
David.
Last edit: 3 years 7 months ago by wouldyou.
3 years 7 months ago - 3 years 7 months ago #214267
by Oilman
I pulled the radiator down today. The core is a modern type with a plate top and bottom and tubes (not the old type with the individual tubes and rubber grommets,). The tubes all look clear, so no cleaning required. The tanks top and bottom are made from 3/16" plate. I will have them sandblasted inside and hoping I can just run some beads of weld to fill where required but won't know until I see how bad they are. Wondering if I could paint the inside of the tanks?
The E1 and E3 are both single circuit foot valves. I think the only difference is that they are a different design. There was nothing wrong with the spring, they are perfect condition inside, I think it is just the rubber seat has aged and slightly leaking. Not enough to cause an issue, but won't hold air for a roadworthy.
Last edit: 3 years 7 months ago by Oilman.
3 years 7 months ago #214269
The only concern with painting the inside of the tanks would be if the paint peeled off and blocked some tubes
Im sure there is some sort of coating type of stuff that wont do this, I have no idea what it would be though
