- Thank you received: 537
1975 Atkinson restoration
- Thank you received: 1174
Butt
with time
U'll find U never build m big enuff
PDU wrote: And how about showing us the inside with the epoxy floor job . . . please
It just looks like painted concrete (nothing special) but photo below. I used Light Greay as probably closest to natural concrete color. The scissor lift is there because the shed sat outside for 12 months and the paint on the columns and trusses didn't look great so I repainted them.
I didn't check the timing, the injector pump was just reinstalled with the same timing ie marks on the driveshaft lined up the same as when removed.Eightpot wrote: Appreciate that this is going back a bit, but when refurbishing the engine did you check the injection timing.? With setting the injection point line on the flywheel at the topmost point did the lines on the little windows on the injection pumps line up. If there is wear and the line on the plunger is lower than those at the window sides, fuel injection will be retarded.
- Thank you received: 4757
Whilst having never done this on a Gardner I have done this on old Cat motors and it can make a huge difference at try to start them when cold
If it hasnt been checked it would be well worth checking at some stage because unless it was just checked it will be slightly out as everything wears
