- Thank you received: 126
I wasn't 100% sure when the later model LC was introduced but had guessed about '54, so with the correct date and some other little facts will be able to add further info into my memory banks. Thanks.
ALSO It seems my title to this post attracts the odd Bedford from time to time, like ianoz's J Type (not that it bothers me any ). Unusual combination, and like my tanker/service vehicle/camper creation would be a lot easier to build using photo-shop. :lol: (NB I am not suggesting that is the case with the J Type at all!)
And when paired with an astronomical almanac and a sextant was the world's first GPS!PDU wrote: The chronometer was England's secret weapon . . .
Call in at The Map Shop, Adelaide anytime (my brother's shop) he's always on about this.
He is heavily into GPS's also, lectures about them occasionally and writing a programme that led to him acting as navigator in one of the Australian Balloons involved in International competitions for a while. :dry:
I'm just the dumb member of the family . . . :blink:
Then us Criminals started using daylight saving just to confuse matters.
PDU wrote: Yes, exactly
A Navigator in a Balloon..???
That's a classic Oxymoron, In my opinion...
Sounds easy, BUT, location is obtained using GPS satellites, which will tell you where they assume you are at ground level (often kilometres away when you are several hundred metres off the ground) which error is compounded when several other satellites tell you are some place else! Hmmm? You are somewhere within a very wide area!? Big Bother's programme covers this error relative to the current altitude.
But for the navigator the problem is then increased as wind shifts require a need to change altitude to locate another favourable air flow in the direction the balloon needs to go. :blink: :ohmy: :
Add to all the problems already mentioned one has to be conscious of the fact that there may be a lot more balloons than normally found together, and all trying to go the same way without coming to grief getting tangled together!
Enough on this, but as you can see it is not just a case of going up and waiting for the wind to blow the balloon to the desired location. The navigator is one busy individual and the calculations are far more involved than calculating varying tyre sizes and gear ratios of transmission/drive systems. :whistle:
Personally I'm having enough problems with my Bedford and I'll leave the ballooning jaunts to Big Bother. (NB I have referred to my older brother in this way for many years now - the pun is intended :lol: ).
