- Thank you received: 4757
8 years 1 month ago #167859
Replied by Mrsmackpaul on topic International A40 - 1 Superloader
I would try not use heat as you never really know what its doing to the axle thats just me though
do you have a exploded parts picture to share so we can at least try figure out how its meant to happen?? because at this stage Im just guessing
8 years 1 month ago #167868
by dieseldog
Replied by dieseldog on topic International A40 - 1 Superloader
Paul, we don't want to heat the axle, only the wheel hub as you need to expand the hub away from the axle wedges. And I'm not talking red hot, probably 80 to 100 degrees is enough. A good trick is to touch the area your heating with a grinder and if it starts to go yellow, you've gone too far.
8 years 1 month ago #168150
Replied by Swishy on topic International A40 - 1 Superloader
The Q:? on everybodys lips
Iz Sarge :-X stihl wrestlin with the Beast
n
Hoo won
n
Hoo won
8 years 1 month ago - 8 years 1 month ago #168188
Replied by Sarge on topic International A40 - 1 Superloader
No wrestling going on here, just sitting in the corner rocking backward and forward.... there is another word starting wiff W
causing me some angst; all Inter related... so we had a long weekend away with all the kids and G.Kids.... but these things dont fix themselves... :side:
Ol' mate is putting off his back operation to come and re-tap the holes later this week.... while I work out how to get the concrete delivered and spread.... :ohmy:
Last edit: 8 years 1 month ago by Sarge.
8 years 1 month ago #168190
looks like number one the big cast center has to be pushed off the wedges not the wedges pulled out and I dont think it will take much to shift it either its like a big morse taper or better still a taper lock vee belt pulley if thats the correct term
So put the heat away longer bolt in the center of the axle a big steel bar some blocks of wood one side and a porter power on the other and jack away and push the big cast center off the wedge
as I have said before it shouldnt be to hard to get off you just got to know how to attack it
8 years 1 month ago #168437
Well Paul, I heard you and tried all my limited tricks under the supervision of my mate who knows about fixing this stuff.... we put pullers and pushers on it, tapped out the ruined hole, and bolted the bejabbers out of it... cooked it up enough to fry eggs, cold water shocked it, and belabored it with the end of an FB heavy bar (no room to hit with a hammer).... I lost 3 kilos.... but no movement. :dry:
We now have re-arranged the puller so it pushes the wheel in while pulling on the wedges, put it under load and every time I go near it I bar the crap out of it.... sometime soon it should go POP... and slip back to the retaining bolts???? :blush: :S Please..
8 years 1 month ago #168543
by Bluey60
Replied by Bluey60 on topic International A40 - 1 Superloader
You know what they say about a watched pot won't boil
get away from it for a few days come up to Qld and look/buy
a new toy and by the time you get home it might have popped off
Bluey
Bluey
8 years 1 month ago #168602
by dieseldog
Sarge, to get a hit on the axle, find a bit of round bar about the same size as the axle and of sufficient length, drill and tap a thread in the end of it and screw it on to the axle. If the axle is a female thread, just use a piece of HT threaded rod to join the two.
8 years 1 month ago #168640
I took Bluey's advice as soon as I saw it and walked away... didn't read the whole message though and have not gorn to Quinsland.
DD I read what you say but not sure if it is gunna work. The axle end is a half inch inside the wheel hub, it has a retaining bolt threaded into it, which I have variously removed and replaced when trying something different with the puller.... now that I am pulling the wedge out as I am pulling the wheel in, I cant get at the the axle .... photos to follow.... might be time to work off a few hot x buns and Easter eggs with the heavy bar in any case. :S
8 years 1 month ago - 8 years 1 month ago #168677
ok here is the game I am playing...
some pulling in each direction
you can see the orginal centre bolt, I have remove the washer and put an old nut as a packer under it, the centre was machined out to rest the puller in, but we have now changed to pushing on the rim rather than the axle.
bolts used in fashion as designed originally as well....actually you can only see the head of a 13/16 tap being used instead of a bolt, cant get a 13/16 unf bolt....
and what the other side looks like in its natural state.
