- Thank you received: 1739
Late 354 Perk.
- Thank you received: 4738
JOHN.K. wrote: Yep,never had a moments trouble with the Perks,now the Inter petrols,they ran so hot that every time you stopped anywhere they would pour out water and leave a yellow stain all over any concrete you parked on.Downright embarrasing at the supermarket,people would be telling you your radiator was leaking all the time.The day all the Perks were replaced with jappas was the day Australia started going downhill.Now we re on a very steep slope.
and in angle gear , better hang on for the ride
- Thank you received: 22
I have an old shop manual and have worked on the NA Perkins with CAV pump withoit any drama, just thought I'd ask if anyone has some good tips if the Turbo engine is any different.
As the pump bloke said, these things seem to suffer a bit with vibration and will often end up shuffling around & wearing the gasket. It's also leaking some fuel as well as engine oil so the time has come for a pump birthday. Parts are available, wonder if they can turn it around this week?
There is an O ring around the pump mounting adaptor plate, haven't sorted out how to repair the stripped stud. This plate also has a bushing to carry the pump drive. Guess I should look at that. Does anyone know what sort of tolerance they should run?
the next trick is going to be getting the injectors out. I've got the clamps off but they don't seem too keen to move with some gentle encouragement from a pair of pliers. I've just been giving them a dose of inox for the moment. Is there a good method? Do I have to make a little puller or slide hammer to screw onto the thread??
Anthony
Heritage Stonemason
