Late 354 Perk.
6 years 3 months ago #190056
Replied by Swishy on topic Late 354 Perk.
RE: haven't sorted out how to repair the stripped stud.
Helicoil .......... insert thread repair
6 years 3 months ago #190066
Replied by Dave_64 on topic Late 354 Perk.
That injector ripper-outer would be sixty bucks well spent.
- Thank you received: 22
6 years 3 months ago - 6 years 3 months ago #190071
by invested energy
Last edit: 6 years 3 months ago by invested energy. Reason: wrong picture
6 years 3 months ago #190072
by 600Dodge
Replied by 600Dodge on topic Late 354 Perk.
No eBay APP ID and/or Cert ID defined in Kunena configurationMaybe better off with one of these
and a length of chain to attach the diesel to a boat in need of an anchor.
6 years 3 months ago #190073
by invested energy
Har bloody har...
Wasn't it Dodge that took the Perkins to the US because that can't build a Diesel to save themselves??
I digress... I wrote a better post and the forum ate it apparently.
Here are the pictures of the injector with what I thought was a sheet metal insert around it. Turns out it was mummified rubber which I picked out with a screwdriver. At least there's a recess to hold some Inox.
6 years 3 months ago #190074
by invested energy
The home made slide hammer ended up being converted to a puller.
#2 thru #6 was easy enough but #1 is still in place. It's damaged the puller thread a bit it's stuck so fast. I'm hoping it'll yield being left under tension overnight. Perhaps I'm putting too much faith in Inox but I don't know what else can be done for it.
6 years 3 months ago #190075
by invested energy
6 years 3 months ago #190076
by 600Dodge
www.gumtree.com.au/s-ad/goolwa/trucks/in...uck-parts/1158615589
you might still need the engine crane but this lot will cure the diesel problem and stay with an Inter engine.
6 years 3 months ago #190077
by dieseldog
Replied by dieseldog on topic Late 354 Perk.
Try putting a spanner on the injector body and giving it a turn. You can try it both ways, but if it’s really easy anticlockwise, you’ll just be unscrewing the cap off the body.
- Thank you received: 546
6 years 3 months ago - 6 years 3 months ago #190078
Replied by Blackduck59 on topic Late 354 Perk.
May need to go back to the slide hammer and drive it in then out and keep alternating and using the Inox.
Had to get some injectors out of a SsangYong 2L and it took ages driving both ways to break up the crud locking them in.
Heaps of Nickel Anti seize around the OD when reinstalling. Poor design as no O ring to keep oil / water / dirt out of the space between the injectors and head.
Last edit: 6 years 3 months ago by Blackduck59.
Time to create page: 0.502 seconds
